WtF! Any input plz. - Printable Version
+--- Thread: WtF! Any input plz. (/showthread.php?tid=43924)
WtF! Any input plz. - redstar - 10-05-2012
What about fuses. There is a big red individual fuse on the side, check that. Buddy had similar issue, that fuse caused it.
WtF! Any input plz. - Str8kaos* - 10-07-2012
You guys have no clue as to what me and RO$$ have went through the last 3 days with this fucking bike! he's got two backup 636's and we've literally swapped out everything to see if anything would change......NOT SHIT HAS CHANGED So that being said right now bike turns over no problem but!, has no spark,no fuel pump "primage" and secondary butter flys which open and close when keys is turned out also not functioning! ABout to be one sold kawi if nothing changes! We're going to swap one more wiring harness in it tomorrow and see if it changes anything if not IM FUCKED OUT OF A BIKE AND REST OF SHOWS THIS YEAR iM tired of hearing the same ol check Fuses,tip,comp,&Cam sensor they've all been re-placed! that being said if you've got anything other than that that could solve the issue plz text me 336 655 2334 much appreciated
WtF! Any input plz. - Duane S. - 10-07-2012
Check or switch wire harness also try the ecu might have went bad maybe
It's more electrical than anything else. You changed fuel pumps so that can't be it. Mine did this before because the pump was giving my bike to much gas like u took the connector hose off and it was pouring gas out
WtF! Any input plz. - PowdaB - 10-07-2012
Check ur ignition wires. Wires are known to come loose on the back ignition.
WtF! Any input plz. - RUTHLESS RAH - 10-07-2012
yo did u check for codes like i said?
WtF! Any input plz. - loogie - 10-07-2012
You fix this?
