Brembo that u can switch from 18-20mm? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: Brembo that u can switch from 18-20mm? (/showthread.php?tid=43832) Pages:
Brembo that u can switch from 18-20mm? - kirny - 09-28-2012 15? I thought they only made the 16 and 19.....so is the 15 a 15mm? Brembo that u can switch from 18-20mm? - StrictlyStunt - 09-28-2012 Need one that goes from 13 to 16
Brembo that u can switch from 18-20mm? - JohnnyP - 09-28-2012 Those are bore sizes, these masters do not allow bore changes, they only let you change the pivot distance.. Brembo that u can switch from 18-20mm? - StrictlyStunt - 09-28-2012 Quote:
Brembo that u can switch from 18-20mm? - JohnnyP - 09-28-2012 Quote:
Edit: Possibly a 16mm with adjustment to feel like a 13mm Brembo that u can switch from 18-20mm? - kirny - 09-28-2012 ^^^ur not understanding thus concept lol Brembo that u can switch from 18-20mm? - StrictlyStunt - 09-28-2012 lol no I get it I just explained it like a retard. I'm saying I would love a Magura 13mm master with pivot adjustment so I could make it stiffer. Especially in the winter time when my fingers go numb.
Brembo that u can switch from 18-20mm? - J Blox - 09-28-2012 I use the rcs 19 for my front brake. its tits. Thought about using it to try a 8 piston but it was a lot of work to swap all the shit around. Brembo that u can switch from 18-20mm? - anarchist35 - 09-29-2012 Quote:
![]() the rcs 15 is great on a 4 piston. i like it but its a tad squishier than a 16x18 but not like a magura 13. the rcs 15 does 15x18, and 15x20, and the rcs 16 does 16x16, and 16x18 |
