636 white oil sludge - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: 636 white oil sludge (/showthread.php?tid=40608) Pages:
636 white oil sludge - DoWheelies - 06-14-2012 this is one for the books. so i took it apart. turns out the water pump impeller bolt sheared off in the shaft somehow. when that sheared off it released the pressure on the mechanical seal, letting them mix. this also explains why the cap wasnt working right properly/consistently. this would explain overheating, coolant/oil mix. so before you go dropping the motor and ripping it apart for a HG like a lunatic, (me), be sure to check this first. so the shaft, impeller, and all seals are ruined. luckily im getting parts off a blown up 06 in town right now so it will be back together tonight. im the guy who could blow a motor from a damn oil air bubble. thanks for the help OMR n sketch 636 white oil sludge - old man roger - 06-14-2012 There might be something in your cooling system, like a dropped bolt or nut. I cant see any other way that bolt would break unless something jammed the propeller. 636 white oil sludge - DoWheelies - 06-14-2012 i think i have an idea. a little too much water in the coolant, and a cold shed in an indiana winter. 636 white oil sludge - old man roger - 06-15-2012 Quote:
636 white oil sludge - Ethiopian - 06-15-2012 Quote:
636 white oil sludge - ReCkLeSsRyAn - 06-18-2012 lol 636 white oil sludge - WiseGuy - 06-18-2012 great info, and a good laugh too... thanks etho 636 white oil sludge - Ethiopian - 06-19-2012 its was pure bullshit, was mad and happy at the same time lol 636 white oil sludge - StuntBikeJake - 08-05-2012 Bump....... hopefully someone can offer some in-site into my current problem... stuntride.com/vbstunt/showthread.php?t=42279 |
