Is 140 links enough? - Printable Version
+--- Thread: Is 140 links enough? (/showthread.php?tid=36083)
Is 140 links enough? - J Blox - 02-03-2012
Swing arms are different lengths between the years, so unless you had an 09+ you might not give the right info...Although a 140 link would be enough to run pretty much any gearing...
Yeah.. that was pretty much my thought. I couldn't tell him he woul dneed 127 links.. but i could tell him what would be enough to just shorten it when it came in.
Is 140 links enough? - Deshi Kicks - 02-03-2012
Shit I didn't know you had kawis. I figured it'd be enough but just wanted to make sure. Not buying fairings, so that leaves me room for an RSC and exhaust.
Is 140 links enough? - !!stretch!! - 02-03-2012
don't tell blox your hard earned cash is going toward an rsc....haha
Call me old fashion I just don't see the point..
you made your point to me..and i totally understand...bought mine used though lol
What, are they not worth it?
And would 130 links be enough? It's $10 cheaper.
Is 140 links enough? - TRICKY - 02-04-2012
stock is 16/43 with 112 links as far as I know, when running 16/60 I think you will need 122 links.
if you run 15/57 which is the same as 16/60 you might only need a 120 chain.
Is 140 links enough? - Deshi Kicks - 02-04-2012
That's a good idea, but the 130 chain is only $10 more where as the front sprocket is like $20. That's two packs of cigarettes I can save! Haha
