08 wr250x Stunt Build... Check it out! - Printable Version
+--- Thread: 08 wr250x Stunt Build... Check it out! (/showthread.php?tid=35211)
Pages: 1 2 3 4 5 6 7 8
08 wr250x Stunt Build... Check it out! - Stubbz63 - 01-08-2012
crank that idle get rid of that decompression breaking that shits horrible, lil idle itll do whoolies by itself lol
08 wr250x Stunt Build... Check it out! - ajbsays - 01-08-2012
red tubing, red chain and sprocket.. custom sprocket.
08 wr250x Stunt Build... Check it out! - Stubbz63 - 01-09-2012
looks good
08 wr250x Stunt Build... Check it out! - ajbsays - 01-09-2012
thanks stubbz, wrap will be all on by this wed! then the only thing left is the dcb and gpr and then some riding time lol!
08 wr250x Stunt Build... Check it out! - ajbsays - 01-11-2012
side view
closer up
front shroud cut down and wrap
rear shroud
swing arm wrap, bad boyyyy
08 wr250x Stunt Build... Check it out! - SQUINTS - 01-11-2012
Looks sick man. Good work setting it up
thanks squints,, and its way faster then stock with that auto tune,, i know its still a 250 but i had her up to 92 the other day and she was still pulling!
Damn!!! Hell ya post up some vid! I should have fucked with the one I had before getting rid of it. If I could have hit 92 I would have probably kept it. U get a speedo healer? Or is it reading 92 w that big sprocket???
i got the speedo healer.. it hit 92 with stock gearing, but i would have hit higher then that i let off the gas, im guessing im still going to hit mid 70s- low 80s with that sprocket...
08 wr250x Stunt Build... Check it out! - R1wonder - 01-11-2012
Syracuse FTP !!
