rolling burnouts - Printable Version
+--- Thread: rolling burnouts (/showthread.php?tid=32259)
rolling burnouts - ernie - 09-28-2011
i tend to forget I have them most of the time
rolling burnouts - ajbsays - 09-28-2011
just looking for some insight, like what gear , speed , for lots and high ways im just curious.
rolling burnouts - JohnnyRocket - 09-28-2011
5th gear revlimiter good for everywhere
rolling burnouts - JCSethro - 09-28-2011
seems like every vid i been watchin lately with street footage someone is rolling a nasty burnout all over the place. i gotta nut up and try these
rolling burnouts - M.F. Mall Cop - 09-28-2011
Originally Posted by JohnnyRocket
Somebody post the yut ugh video that guy gives a detailed explanation I think you use the front and rear brake at the same time
Naw man thats for drifts. Dont forget bigger sprockets.
common sense should tell you that you should start trying them in the lot in first gear.
Why dont you start a regular burnout and then start letting it roll?
rolling burnouts - GIL with 1 L - 09-28-2011
Originally Posted by ajbsays
Lean forward.bang limiter,pop clutch ,apply psi to front brakes before bike gets speed ,back off throttle .practice alot
rolling burnouts - my750 - 09-29-2011
Originally Posted by Paul
i thought mine was detailed... what more do u wanna know?
i thought it explained things good enough for me to try it this weekend
rolling burnouts - loogie - 03-28-2012
i grab a lil front brake... then while the clutch is engaged i "blip" the lever while simultaneously giving it a lil more gas to get the back wheel spinning. also i keep my weight forward over the tank to help break the wheel free. and as for what gear... since i suck i only do em in 1st gear in the lot
Tankhumper.
rolling burnouts - Rdot302 - 04-11-2012
+1
I only do em in first in the lot but pretty much break down to almost a stop and i have steady pressure as i work the clutch to free the rear tire i lean forward and flick the front brake in all the way than back out to my pressure spot where i had it. youll wash out to the side and have ot throw a foot down if u give it too much throttle just takes some practice. after that its just front brake control to control your speed and where you want the bike to go
