Fawk you vortex cap - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: Fawk you vortex cap (/showthread.php?tid=27986) |
Fawk you vortex cap - sQuiD FigHTer - 05-25-2011 Indeed sir Fawk you vortex cap - loogie - 05-25-2011 they make a "metal tank repair" 2 part putty you can get at any auto parts store that is the biznisssssssss Fawk you vortex cap - RUTHLESS RAH - 05-25-2011 on a stock cap too??? only reason i ask is because i have broken gas cap bolts and my tank leaks now Fawk you vortex cap - sQuiD FigHTer - 05-25-2011 Yep I use quick steal because u can form it to how u need it and it's like steal after it sets... It's sandable paintable and u can drill and tap it if need be Fawk you vortex cap - RUTHLESS RAH - 05-25-2011 nice, i think i'll do that tomorrow instead of trying to drill and back out them broken bolts...thanx for the info bruh, ur da man
Fawk you vortex cap - !!A2K!! - 05-25-2011 stock cap takes care of the problem..... Fawk you vortex cap - sQuiD FigHTer - 05-25-2011 Yea I wish I could get a stock cap on mine but the guy who had the bike before me made that a no go Fawk you vortex cap - kevin09 - 05-25-2011 i thought gas ate jb weld? or do they make "gas resistant" jb weld...? yeah and u can shape it to make ur tank look somewhat clean Fawk you vortex cap - old man roger - 05-25-2011 if you have the type of vortex cap that has the little check ball in it take out the little ball and spring from the base then seal the base to the tank with a rubber gasket ... the ball and spring always end up sticking allowing pressure to build in the tank and that pushes out almost any gasket but if the ball and spring are gone any pressure will bleed out the over flow .. Fawk you vortex cap - Mack-a-Billionaire - 05-25-2011 i had that problem on old f4i...i put a big "o ring" from a washtud/shower drain around the base (way thicker then the vortex one) then I took a grinder to the base where the pegs stick out where you would run your allen bolts down and took a little material off so the base would sit down and be a lil countersunk in tank...worked good! |
