Longer Clutch Cable for F4I?? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.org/forumdisplay.php?fid=12) +--- Thread: Longer Clutch Cable for F4I?? (/showthread.php?tid=21725) Pages:
Longer Clutch Cable for F4I?? - Diesel_Stunts - 12-21-2010 ^^^Winner! I remember that it would do that sometimes, nice call buddy Longer Clutch Cable for F4I?? - Ethiopian - 12-21-2010 secure it somehow so it stays on the inside of the cap. thats what i did. Longer Clutch Cable for F4I?? - MiNi GuineA - 12-21-2010 Your not doing something right, I have a stock cable with 7 degree vortex clamps on, 2 inch rise dcp clip tubes, on a hohey tree with 954 forks. thats a 2 1/2 inch rise with fatter forks and my cable is on the outside of the fork tube. Longer Clutch Cable for F4I?? - Raider - 12-21-2010 I HATE when that happens! Grrrrr. Always happens as I slide into a drift and I tip over. Lol. I actually cut the protruding parts off the cap and its way better. Longer Clutch Cable for F4I?? - sevenf4i - 12-25-2010 ran my cable threw the forks and zip tied it to the frame. seem to work fine. Longer Clutch Cable for F4I?? - danger_dave - 12-25-2010 i found that the stock cable is actually way long if you have clipons. mine got all nestled up on one of the fittings for the overflow on the radiator, and it wore a hole in it and pissed hot coolant everywhere! Longer Clutch Cable for F4I?? - 1997f3 - 12-25-2010 i run DB and stock worked. just play with it and re route it. If that doesn't work... then shit. lol ![]() merry christmas |
