R6 Subframe help!!! - Printable Version
+--- Thread: R6 Subframe help!!! (/showthread.php?tid=21604)
R6 Subframe help!!! - DILTS - 12-18-2010
Originally Posted by LilJohnStunts
hey atown, how much and would i be able to mount everthing like a stock sub frame, including a 12 bar?
Atown's mini 12/round bar is nice!
R6 Subframe help!!! - BLEED - 12-18-2010
you can't rock stock subframe. Those things are a waste. You gotta up grade. A 12 bar won't save it nor will a subcage. That's how weak they are. But deff do s upgrade. I been rocking atown for 1yr half and its still holding up like butter
R6 Subframe help!!! - jc_hernandez_wtsn - 12-18-2010
http://stuntride.com/vbstunt/showthread.php?t=21466
did you see this?
Every thing you have on your stock subframe will mount on the c4 sub. but you might want to go with the c4 strape bar.
R6 Subframe help!!! - douggiefresh - 12-18-2010
get a atown my buddy has one and i plan on getting one soon
http://atowncustoms.com/store/subframes-c-23.html
Both subframes are good c4 and atown. anything is better then stock. everything bolts up the same as stock
R6 Subframe help!!! - reds919hornet - 12-19-2010
i will have to find it but i think atown said only his 12 bar will bolt right up to his sub-frame . and c4 web site is down right now. heard he is taking some time off please someone correct me if i am wrong.
R6 Subframe help!!! - str8billed636 - 12-19-2010
I'll text atown now but I know he built the steel subframe for the exact specs of the stock one.. So I don't know why u couldn't use any bar.. But it would be cheaper to order them together... And his shit is really tight to the bike and looks sick!
Originally Posted by str8billed636
may have been his 12 bar only works with his sub frame. i do not remember. we talked about it over a year ago on myspace and i can not find the messages.
anyone know what is up with dave at c4?
R6 Subframe help!!! - Atown1101 - 12-19-2010
C4 is taking a time out form what i heard so idk!
and yes only my 12 bar will work with my sub
