Motorcycle tire changing machine! - Printable Version
+-- Forum: Classifieds (https://stuntride.org/forumdisplay.php?fid=6)
+--- Forum: Wanting to Buy - Bikes (https://stuntride.org/forumdisplay.php?fid=16)
+--- Thread: Motorcycle tire changing machine! (/showthread.php?tid=216)
Motorcycle tire changing machine! - zx636skiv - 02-22-2006
Originally Posted by john LegionST
...we break the bead with a ramp...
Once you let the air out of the tire, you can also use a kickstand to break the bead. If you are gonna do that, why not just pick up a couple tire spoons...only a couple bucks a piece and they work better than screwdrivers!
Motorcycle tire changing machine! - thomas - 02-22-2006
at a show you just use a bead breaker and spoons of course..
but when someone says "machine" to me.. I think of shop use
Motorcycle tire changing machine! - Yogurt - 02-22-2006
I think you can get this one for around $700 It is the best one I have used.
Coats Model 220 Motorcycle Tire Changer
The Coats Model 220 motorcycle tire changer is a simple to operate manual tire changer designed to handle motorcycle wheels, including custom alloy wheels and tubeless tires. The model 220 is also versatile; also service lawn and garden, tractor, golf cart, trailer, automotive, and ATV wheels with a minimum amount of time and effort. The model 220 is designed and built in the USA, and built to last.
Features/Specifications
Handles a wide range of wheels - one set of rim clamps will service wheel diameters 8 inches to 17.5 inches, and a second set of clamps will service wheels from 14 inches to 23 inches.
Handles small hole or no center hole wheels - model 220 all purpose tire changer allows you to service wheels such as those found on Renault, Peugeot, and Fiat.
Less work, faster operation - specially designed outside rim clamping assures positive hold down without adapters. No need to remove brake discs or sprockets. Wheel is at convenient working height, no bending over.
No rim denting or scratching - special replaceable plastic protectors on demount/mount tool and plastic pads on the rim clamp prevent denting, scratching and damaging of wheels.
Handles stubborn beads and tubeless tires easily - an easy to use bead loosener simply handles stubborn beads and tubeless tires.
External three point clamping system - this method of wheel hold down eliminates hub and spoke stress which allows excellent manual servicing of delicate mags and wire wheels.
Built to last - all steel construction, one year warranty
Weight: approximately 130 lbs.
Has bead breaker attached to unit, comes with mount/demount tool.
Price is $859.00 delivered, ships by truck
Accessories
Part Number 107423: Combo Tool Protector Set, package of 12 pieces total, six protectors for each end of the mount demount bar, protects chrome and painted wheels against scratches - Price is $39.95 plus shipping (UPS)
Part Number 107424: Clamp Pads for the vise on model 220, package of 36 plastic clips - Price is $44.95 plus shipping (UPS)
I like this one because you dont have to worry about scratches.
http://www.nomartirechanger.com/NoMarmainFrameset.html
yeah $400 more and you get a fully automatic one
Give the info!
its in the first link I posted.. and I have personally owned one
Motorcycle tire changing machine! - Nick App - 02-23-2006
damn! this forum is the shit. Ive been on here for a couple of days and I learn something new ever time I get online. im buying one of those tire changing machines for sure.... so what one should I go with?
Motorcycle tire changing machine! - zx636skiv - 02-23-2006
Probably depends on how much you can afford...if $50 is your limit, go with the harbor freight one, if you have more money, go with the higher dollar items. I don't know about the other changers, but the harbor freight one is fine for what I've used it for, as long as it is bolted to a stable base.
Motorcycle tire changing machine! - Malibu_Rhonda - 02-23-2006
Stuntragz has a portable bead breaker and tire changing kit for $85. http://www.stuntragz.com/Templates/tire_changer.htm
We just filmed the commercial for it and Jakob B. had his back tire off the rim in less than 4 min.
Check it out!!!
Motorcycle tire changing machine! - nickalltogether - 02-23-2006
Check it out!!!
4 minutes... that's quick.
