Mean Tank Slapper - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Videos and Reviews (https://stuntride.org/forumdisplay.php?fid=10) +--- Thread: Mean Tank Slapper (/showthread.php?tid=16381) Pages:
Mean Tank Slapper - FarMDER - 07-14-2010 damn! i wouldve dropped that shit for sure. dont the new 1000rr's come stock with dampners? Mean Tank Slapper - Bobby digital - 07-14-2010 all you gotta do is get off the throttle i used to get it on my 10 all the time(not that bad though and all i ever had to do was come off the gas Mean Tank Slapper - tys0n - 07-15-2010 yep had em a few times just let go of the throttle and wa la if you look close you can see him let go of the throttle. Mean Tank Slapper - sa23 - 07-15-2010 i have got the 09 1000cc it dose come with a stock damper but thay dont work good for stoppies so i changed my one to a grp damper thay are a fun bike to ride i use my one for stoppies Mean Tank Slapper - Str8kaos* - 07-15-2010 thats actually the opposite of what you wanna do that + disaster.if you listen he actually stayed on the throttle which corrected it somewhat then he went into the grass.
Mean Tank Slapper - Bobby digital - 07-15-2010 if you stay on the gas you can accidentilly make it worse sometimes by the bars causing you to gas harder and harder...iknow if you accelerate hard enough to take the tire off the ground it will go away but if you dont do it right it just makes it worse..........either way around it i havent ever had it get that bad so i may be wrong but thats what ive always done Mean Tank Slapper - TheRomanSF415 - 07-15-2010 When it's slappin that hard i think no matter who it is , they're just holding on for the ride Mean Tank Slapper - Crazy Justin - 07-15-2010 thats just brutal... lucky ass guy Mean Tank Slapper - tys0n - 07-15-2010 I have tank slapped at least 5 times, Watched a friend of mine slap for almost a whole mile and still saved it, skin from his knees was rubbed off on the frame. You guys do what you want but when i get a bad slapper ill let off the throttle straightens out abruptly everytime. ![]() Now if your headed off the road or something thats another story and its def hard as fuck to let go of the throttle when its such a violent movement but def not impossible. Its proven that staying on the gas will make it worse My dirtbike use to slap all the time when it was wide open cause it was old but it only happend when i was full throttle and the wheel got loose on the dirt, id let off and bam it stopped. |
