04 636 Build... - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.org/forumdisplay.php?fid=104) +--- Thread: 04 636 Build... (/showthread.php?tid=12452) |
04 636 Build... - vegasrider2005 - 10-14-2026 \r\n \r\n Looks sick brendon, cant wait to try it out \r\n
04 636 Build... - vegasrider2005 - 10-14-2026 \r\n \r\n \r\n O-no yes it is why???\r\n
Quote: \r\n
04 636 Build... - Cjones - 10-14-2026 \r\n \r\n looks sick, doin work!\r\n 04 636 Build... - MVSBrendon - 10-14-2026 \r\n \r\n \r\n yeah, 3/16 steel bracket mounted to the stock bracket. It works......\r\n
Quote: \r\n
04 636 Build... - MVSBrendon - 10-14-2026 \r\n \r\n ![]() \nStripped down and dirty... \n ![]() \n06 swingarm is on \n ![]() \nBracket mounted.... \n ![]() \nDone for the night..... \n \nNeeded to run the 04 spacer and through bolt for the swingarm and needed to mod the chain guide a little, other than that, it was a straight forward swap...\r\n 04 636 Build... - RKArmor - 10-14-2026 \r\n \r\n thats a cool setup man props on the design \r\n
04 636 Build... - 6Dirty6 Rey-Rey - 10-14-2026 \r\n \r\n looks super nice ...keep up the good work\r\n 04 636 Build... - MVSBrendon - 10-14-2026 \r\n \r\n \r\n thanks manQuote: \r\n
, maybe we can work out a trade. I\'ll send you a bracket and you can send me a cage..... my 905 shit is getting beat. \r\n
04 636 Build... - MVSBrendon - 10-14-2026 \r\n \r\n \r\n Totally agree. The footbrake took a little getting used to, but after that, it\'s the best set up I\'ve had to date. Looking forward to having the bigger rotor though......\r\n
Quote: \r\n
04 636 Build... - MVSBrendon - 10-14-2026 \r\n \r\n 06 wheels and swing arm are done. \n ![]() \n \nbrake lines run and bled. \n ![]() \n \n \r\n
