My 2003 636 Build - Page 2 - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Pictures (https://stuntride.org/forumdisplay.php?fid=32) +--- Thread: My 2003 636 Build - Page 2 (/showthread.php?tid=12094) Pages:
My 2003 636 Build - Page 2 - old man roger - 03-10-2010 did you weld up a frame that wasnt broke ? My 2003 636 Build - Page 2 - T-Dubby - 03-10-2010 Yes
My 2003 636 Build - Page 2 - old man roger - 03-10-2010 i have been stunting crashing pancaking mousetrapping and smashing curbs with my 03 since 05 and my frame has held up fine i just keep my motor mounts tight .. every frame i have seen that has been welded has cracked right at the weld My 2003 636 Build - Page 2 - T-Dubby - 03-10-2010 Quote:
Also if I'm seeing some oil at the top near the head should i replace that gasket? My 2003 636 Build - Page 2 - old man roger - 03-10-2010 Quote:
the problem with most reinforced frames is the welds penitrate the frame too deep and weaking it ,the vertical welds are usually the ones that fail My 2003 636 Build - Page 2 - T-Dubby - 03-10-2010 Quote:
![]() Here's the one he's building now
My 2003 636 Build - Page 2 - T-Dubby - 03-10-2010 Dude it's amazing what he's done on that thing.. My 2003 636 Build - Page 2 - SKETCHY - 03-10-2010 Can't wait to see the finished product. Also, I dont blame you a bit for bracing the frame from the get go. I'm gonna do this to every bike I get from here on out!! My 2003 636 Build - Page 2 - J Blox - 03-10-2010 Roger, since we are talkinga bout bracing. I was thinking when i do my next frame. putting dry ice around the rest of the frame to isolate the heat to just the weld area? Also this should help disapate the heat throughout the frame faster? Your thoughts? |
