Two fingering? - Printable Version +- Stuntride (https://stuntride.org) +-- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.org/forumdisplay.php?fid=9) +--- Thread: Two fingering? (/showthread.php?tid=11173) |
Two fingering? - Guru - 02-09-2010 I one finger it all the time and just grab the clutch when i need it.... i dont clutch n use hb with the same finger... Two fingering? - StrictlyStunt - 02-09-2010 what about with your suicide circles? or coasters... 2 finger it then? Two fingering? - Guru - 02-09-2010 yeah.... when i need or wanna use it i 2 finger it.... i just dont ride around with both fingers on the levers all day.... Two fingering? - rr boss - 02-09-2010 depends on the trick idle stuff i use 2 fingers faster stuff and combos i just cover the brake Two fingering? - Guru - 02-09-2010 guys Two fingering? - da Liks - 02-09-2010 men.. Two fingering? - Chris636 - 02-09-2010 nah thats two fingers and a pinky lol Two fingering? - krazykyle85 - 02-09-2010 always 1 finger on the clutch and 1 on the handbrake. any other way is wrong ![]() i use the clutch allllll day! if my handbrake sucks, because it is hot or old brakefluid or something, i use the clutch to disengage some of that amazing kawi power... and the hohey handbrake works amazing with this method and i am able to save 90 percent of my squidlyness ![]()
Two fingering? - SKETCHY - 02-09-2010 thats what i thought this thread was going to be about
Two fingering? - lot lizard - 02-09-2010 If u crash w/o clutch covered it can go very bad if u come down and twist the throttle make sure put a little slack in throttle cables when learning |
